Старый 03.07.2013, 17:49   #1
Ende Juni wurde ein Update für Sure Step Online veröffentlicht. Folgende neue Inhalte wurden hinzugefügt:
  • Microsoft Dynamics AX 2012 Business Process Flows – the business process flows found in the Analysis phase have been updated for Microsoft Dynamics AX 2012. The AX 2009 business process flows have been retained.
  • Microsoft Dynamics NAV 2013 – the Dynamics NAV content was updated for the 2013 release. You will find this content to be more streamlined in regards to implementation methodology. RoleTailored implementation guidance which was first introduced in Sure Step has now moved to PartnerSource. Additionally, a guide to RapidStart has replaced the former rapid implementation guide. To make it easier to find these valuable tools on PartnerSource, a resource guide with links to PartnerSource tools is downloaded to each new project.
  • Key Documents View – A diagram of the Sure Step process highlighting the most basic implementation templates has been moved ‘to the top’ of the Methodology view and can now be opened under the “Microsoft Dynamics Sure Step Methodology” selection. This provides a concise view and the shortest path to a successful implementation using only the core Sure Step templates.
  • Connector for Microsoft Dynamics – you can now find a page dedicated to Connector solutions under the Additional Resources tab. This has been updated to include quick access to the latest information on the Connector solutions, including the team blog, installation video, and user guides.
  • Management Reporter – Management Reporter takes its place under the list of “Microsoft Dynamics Solutions” in the Sure Step content where you can find links to numerous online resources for Management Reporter. While we have maintained references to Management Reporter through the various ERP implementation materials, you will now see a dedicated Functional Requirements Document (FRD) for Management Reporter.  Another document that will show up in new projects contains links to many helpful how-to videos for Management Reporter.
Sure Step Online starten
Далее
