Hello all,
I have new info for you - new xp_ndo.dll for SP2 is
solving problems with MS SQL 2005. After that update, it seems that all
critical problems with SQL 2005 are solved and can be used by
customers. There is just minor problem with transaction log max size,
which is read in KB but set in MB (the column has MB in caption, but
what Navision read from SQL is in KB, if you want to set the max size,
you need to enter size in MB...).
I wish you luck in using MS SQL 2005 and many satisfied customers...
Share this post: email it! |
bookmark it! |
digg it! |
live it!
Источник:
http://msmvps.com/blogs/kine/archive...23/100363.aspx
