Старый 17.01.2005, 15:55   #1
Maxim Gorbunov is offline
Maxim Gorbunov
2,483 / 646 (26) +++++++
Сообщение от XML.com: A Technical Introduction to XML
XML Development Goals
6. XML documents should be human-legible and reasonably clear. If you don't have an XML browser and you've received a hunk of XML from somewhere, you ought to be able to look at it in your favorite text editor and actually figure out what the content means.
9. XML documents shall be easy to create. Although there will eventually be sophisticated editors to create and edit XML content, they won't appear immediately. In the interim, it must be possible to create XML documents in other ways: directly in a text editor, with simple shell and Perl scripts, etc.
В общем, бинарный XML - это уже не XML. Как геометрия Лобачевского и Эвклида.
