Старый 22.03.2016, 17:11   #1
emeadaxsupport: IDMF – Archiving Restoring and Purging data from a custom table
Источник: https://blogs.msdn.microsoft.com/axs...-custom-table/
Consider a scenario where you are running AX 2012 R3 and you want to archive or purge data from a custom table in AX using IDMF. The screenshots are from a VM TEST environment with CONTOSO DEMO DATA that is running AX 2012 R3 CU10 on SQL Server 2014 and the latest version of IDMF.... Read more
