Старый 23.11.2015, 11:01   #5
Logger is offline
Logger
3,996 / 3293 (117) ++++++++++
Записей в блоге: 2
А теперь запустите ваш код, дергающий xSession::xppCallStack(), в IL - и обломитесь...
Как-то некрасиво x++ себя ведет в этой ситуации.
Попробовал набросать метод замену. Расположил в классе Session.
/// <summary>
/// Splits the given String by the specified separator and returns the contents in a container.
/// GRD_Stuff_pkoz, Перенос "наработок" из 2009-й, pkoz, 22.11.2015
/// </summary>
/// <param name="_value">
/// The String value to be split.
/// </param>
/// <param name="_sep">
/// The separator.
/// </param>
/// <param name="_convertNumericToInt64">
/// A Boolean value that indicates whether to convert the value to an <c>int64</c> value; optional.
/// </param>
/// <param name="_unpackLineNumber">
/// A Boolean value that indicates whether to extract line number from stacktrace string _value; optional.
/// </param>
/// <returns>
/// A container, which has the String split by the specified separator.
/// </returns>
/// <remarks>
/// In the <paramref name="_convertNumericToInt64" /> parameter, a value of true indicates the returned
/// contents will be converted to an <c>int64</c> value if they only have numeric characters.A value of
/// false indicates that the returned values will not be converted to an <c>int64</c> value and String
/// values will always be returned. The default value of the <paramref name="_convertNumericToInt64" />
/// parameter is true.
/// </remarks>
static container stackLine2con(str _value, str 10 _sep = ',', boolean _convertNumericToInt64 = true, boolean _unpackLineNumber = false)
    int         length = strLen(_value);
    int         separatorLength = strLen(_sep);
    int         i = 1;
    int         j = strScan(_value, _sep, 1, length);
    container   ret;
    void add2Ret(str _current)
        if (_convertNumericToInt64 && (match('<:d+>', _current)))
            ret += str2int64(_current);
        else
            ret += _current;
        //GRD_Stuff_pkoz, Перенос "наработок" из 2009-й, pkoz, 22.11.2015 -->
        if ( _unpackLineNumber )
            ret += 0; // пока не реализовано
        else
            ret += 0;
        //GRD_Stuff_pkoz, Перенос "наработок" из 2009-й, pkoz, 22.11.2015 <--
    while (j)
        add2Ret(subStr(_value, i, j-i));
        i = j + separatorLength;
        j = strScan(_value, _sep, i, length);
    add2Ret(subStr(_value, i, length-i+1));
    return ret;
/// </param>
/// <param name="_mode">
/// An Int value that indicates how to convert the value to container; optional.
/// </param>
/// <returns>
/// A container, which has the stack trace.
/// </returns>
/// <remarks>
/// </remarks>
client server public static container xppILCallStack(int _mode = 0)
    str         stack;
    container   ret;
    // int         startPos;
    #define.delimiter("   at ")
    if (!xSession::isCLRSession())
        return xSession::xppCallStack();
    new InteropPermission(InteropKind::ClrInterop).assert();
    stack = System.Environment::get_StackTrace();
    // startPos = strScan(stack, #delimiter, 1, 1000);
    switch (_mode)
        case 0 : // режим, похожий на обычный xSession::xppCallStack() только извлечение номеров строк не сделано
                ret = [
                        (isRunningOnServer() ? "(S)" : "(C)") + "(CIL)", _mode
                      Session::stackLine2con(stack, #delimiter, false, false);
                break;
        case 1 : // быстрый режим, чтобы не тратить процессорное время на обработку строк. Использующий код в дальнейшем сам обработает как надо - распакует и.т.п. А скорее всего просто проигнорирует.
                ret = [
                      [stack, 0];
                break;
    return ret;
А потом подумалось - возможно это велосипед и я просто не нашел нужного кода в стандарте.
Кто как решает проблему получения стека вызовов при исполнении в p-code и CIL ?
Последний раз редактировалось Logger; 23.11.2015 в 12:40. Причина: исправил ошибки
За это сообщение автора поблагодарили: Ace of Database (5).
