Старый 18.06.2015, 05:18   #1
Channel9 CRM: Script# & Dynamics CRM 2011
Источник: https://channel9.msdn.com/posts/Scri...amics-CRM-2011
In this video, I walk you through two core usage scenarios for Script# in the Dynamics CRM 2011 context:
  • Creating JavaScript web resources
  • Sharing basic logic across server-side code (plugins/workflow activities) & client-side code (JavaScript web resources)
Think of this as an alternative approach to producing JavaScript code for Dynamics CRM 2011. I tend to like it for all the same reasons the Script# home page calls out: Intellisense that works!, MSBuild Support, Visualize your Code, Intuitive OOP Syntax, Unit Testing Support, Create Documentation, FxCop Code Analysis. Yes, there are ways to do these things with JavaScript, but Script# lets you use what you already know if you are a C# developer. If after watching this video, you decide it's not for you, then erase it from your memory banks and continue with your current approach.
NOTE: Sorry about the audio quality (echo).
@devkeydet
