Старый 23.03.2015, 22:12   #1
Dynamics AX Sustained Engineering: Announcing an update to enable the use of SQL Server 2014 with the AX 2012 R2 CU7 version of the Data Import/Export Framework (DIXF)
Источник: http://blogs.technet.com/b/dynamicsa...work-dixf.aspx
We are pleased to announce the availability of KB 3018235, which enables the AX 2012 R2 cumulative update 7 version of DIXF to run with Integration Services from SQL Server 2014.
This update is also available in the recently released AX 2012 R2 CU8.
For information about installing and using the hotfix, see:
You can also refer to the Microsoft Dynamics AX 2012 System Requirements for more information.
