Старый 28.02.2015, 14:12   #1
DeniZone: 2 examples of importing multiple files
Источник: http://denizone.blogspot.com/2015/02...ple-files.html
In AX, the typical way to import files via the UI is to do it one file at the time. If you have multiple files to import there are several options on how to do this via the AIF.
Every once in a while, it could be useful for the end-user to have the option of importing several files through the UI.
I have found two similar examples on how to achieve this:
Example 1)
static void MultiFileSelectDlgTest_1(Args _args)
System.Windows.Forms.OpenFileDialog ofd;
System.String[] s2;
int counters;
str imageValaue;
int i;
ofd = new System.Windows.Forms.OpenFileDialog();
ofd.set_Title("Select files");
ofd.set_Multiselect(true);
if (ofd.ShowDialog() == System.Windows.Forms.DialogResult::OK)
s2 = ofd.get_FileNames();
counters=System.Convert::ToInt32( s2.get_Length());
for(i = 0 ; i
