Источник:
http://blogs.msdn.com/b/ax_gfm_frame...ed-topics.aspx
Introduction
Concluding this series of blog posts, this section covers additional defaulting patterns and APIs that can be used in advanced scenarios.
This blog post series includes:
DimensionDefaultingEngine
In the
previous blog post, the
DimensionDefaultingService class was described. It provides the common APIs needed for most defaulting needs. For scenarios not supported by the
DimensionDefaultingService, the
DimensionDefaultingEngine class can be used directly. This class provides all of the logic for the
DimensionDefaultingService class.
The engine leverages a concept called dimension specifiers which is a map of dimensions and values obtained from default dimensions and ledger dimensions. The documentation for the
DimensionDefaultingEngine can be found on
MSDN.
Defaulting during segment entry
In most cases, the merging of default dimensions to a ledger dimension occurs before the user has begun editing the ledger account combination in a segmented entry control. In some circumstances, the form has logic to perform defaulting as the user enters each segment in the control. In order to do this, the form must respond to events raised by the segmented entry control.
To perform defaulting at entry leveraging the
DimensionDefaultingEngine class, the
segmentValueChanged() method on the segmented entry control is overridden. Defaulting can then be based on current values in the control providing values for other segments. This example in Figure 1 adds dimension values from the MainAccount table, merging with other values, as soon as a MainAccount is entered in the segmented entry control.
Figure 1: Sample segmentValueChanged() override to default during segment entry
This concludes this series of blog posts about dimension defaulting.
Источник:
