Старый 23.05.2014, 13:11   #1
emeadaxsupport: AX 2012, a TableMap object turns to be a Table
Источник: http://blogs.msdn.com/b/axsupport/ar...e-a-table.aspx
Issue description:
We have seen some scenarios while deploying Models/ModelStore among multi environments,
that a TableMap object turns to be a Table.
Cause:
Unknown, no consistent repro pattern has been spotted
Resolution suggestion:
We take e.g. that the affected object is the 'CustVendInvoiceTrans' table map.
Run the following SQL script in order to correct the object type:
-- Assumption: Script works against dev model store
-- Assumption: Clean baseline model store is named: axdbdev_model_id_baseline (can be replaced by own naming)
-- Check existence affect object in dev environment
SELECT m.ElementType, m.Name, m.AxId, md.LayerId, manifest.DisplayName, md.Properties as Metadata
FROM [dbo].ModelElement AS m
INNER JOIN [dbo].ModelElementData AS md
ON m.ElementHandle = md.ElementHandle
INNER JOIN [dbo].ModelManifest AS manifest
ON md.ModelId = manifest.ModelId
AND m.ElementType = 44 AND m.Name = 'CustVendInvoiceTrans'
-- Check existence affect object in baseline environment
FROM axdbdev_model_id_baseline.[dbo].ModelElement AS m
INNER JOIN axdbdev_model_id_baseline.[dbo].ModelElementData AS md
INNER JOIN axdbdev_model_id_baseline.[dbo].ModelManifest AS manifest
-- Replace corrupted metadata on dev environment from baseline environment
Update md Set md.Properties = md_base.Properties
INNER JOIN axdbdev_model_id_baseline.[dbo].ModelElement AS m_base
ON m.ElementType = m_base.ElementType AND m.Name = m_base.Name
INNER JOIN axdbdev_model_id_baseline.[dbo].ModelElementData AS md_base
ON m_base.ElementHandle = md_base.ElementHandle
AND m_base.ElementType = 44 AND m_base.Name = 'CustVendInvoiceTrans' AND md_base.LayerId = 0
