Старый 13.04.2014, 14:12   #1
bojensen: AX 2012 Financial dimension update
Источник: http://blogs.bojensen.eu/?p=4840
Here are 2 ways to update a financial dimension, while keeping the other dims. The result should be the same, just use whatever you prefer. To use those two method proceed like so: purchTable = purchTable::find(‘PURCHID’, true);purchTable.DefaultDimension = getNewDefaultDimension(purchTable.DefaultDimension, “COSTCENTER”, “YOURVALUE”);purchTable.update(); METHOD NUMBER 1: static RecId getNewDefaultDimension(RecId defaultDimension, Name dimName, str 255 dimValue){DimensionAttributeValueSetStorage dimStorage;Counter i;DimensionAttribute…
Read more →
За это сообщение автора поблагодарили: gefr (1).
