Старый 27.01.2014, 19:12   #1
sashanazarov: Dynamics AX 2012: orig() method fails on derived tables
Источник: http://sashanazarov.blogspot.com/201...-fails-on.html
Just found a bug in the table inheritance feature (kernel 6.0.1108.5781).
If you have a base table A with field B, and a derived table C with field D, then C.orig().B will return a strange value (or nil, depending on the field type).
In order to get the correct value, you will need to downcast C to A, and then call A.orig().B.
This is the job that reproes the issue:
static void reproOrigBug(Args _args)
CompanyInfo companyInfo;
DirPartyTable dirPartyTable;
select firstOnly companyInfo;
info(companyInfo.orig().DataArea);
info(companyInfo.orig().Name);
dirPartyTable = companyInfo as DirPartyTable;
info(dirPartyTable.orig().Name);
And this is the output:
I will report the issue to MS Support.
