Старый 03.12.2013, 16:16   #2
Omeo is offline
Omeo
129 / 50 (2) ++++
Самое интересное в логе биндов:
*** Assembly Binder Log Entry (03.12.2013 @ 16:11:18) ***
The operation was successful.
Bind result: hr = 0x0. Операция успешно завершена.
Assembly manager loaded from: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
Running under executable \\aos18\axapta\Client\Bin\Ax32.exe
--- A detailed error log follows.
=== Pre-bind state information ===
LOG: User = domain\test
LOG: DisplayName = ResponseTest, Version=1.0.0.0, Culture=neutral, PublicKeyToken=7154e491b05575c8, processorArchitecture=MSIL
(Fully-specified)
LOG: Appbase = file://aos18/axapta/Client/Bin/
LOG: Initial PrivatePath = NULL
LOG: Dynamic Base = NULL
LOG: Cache Base = NULL
LOG: AppName = NULL
Calling assembly : (Unknown).
LOG: This bind starts in default load context.
LOG: No application configuration file found.
LOG: Using machine configuration file from C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\config\machine.config.
LOG: Post-policy reference:ResponseTest, Version=1.0.0.0, Culture=neutral, PublicKeyToken=7154e491b05575c8, processorArchitecture=MSIL
LOG: Found assembly by looking in the GAC.
LOG: Binding succeeds. Returns assembly from C:\WINDOWS\assembly\GAC_MSIL\ResponseTest\1.0.0.0__7154e491b05575c8\ResponseTest.dll.
LOG: Assembly is loaded in default load context.
