Старый 19.10.2013, 02:14   #1
Gareth Tucker: CRM 2013 New Features: New Menu Experience
Источник: http://garethtuckercrm.com/2013/10/1...nu-experience/
Gone is the traditional left hand navigation pane, now we have a top menu that admittedly takes a little getting used to:
Out with the old:
And in with the new:
At first glance the menu doesn’t feel that intuitive.  For example to switch Areas you click on the Microsoft Dynamics CRM dropdown:
This seems strange to me.  But then again, in my experience most customers use CRM for only one functional area and I have commonly ditched Sales, Service and Marketing and replaced with a single custom area named something like “CRM” or “Home” – whatever looks good in the UI.  So I expect it will be common for users to not need to switch Areas making this peculiar user experience irrelevant.
Next level of navigation is to pick a menu item from within the selected Area (i.e. pick Opportunities from the Sales Area).  Here you click on the SALES dropdown, to pick the child menu items that belong under that Area:
It will be common for the number of menu items to exceed the width of the window, so the user will need to use the arrow on the right to scroll across:
The Groups that we are used to from the SiteMap are still there, they appear as subtle headings above the first menu item in each Group.  Not sure I see any value in these now:
Editing of the new menu is done the same way as it was before, either manual XML editing of the SiteMap or via a third party SiteMap editor.
Let’s try trimming the menu down and see if we can’t make the menu a little more intuitive.  I gave Tanguy’s Site Map Editor a whirl and it seemed to work just fine against CRM 2013.  I created a “MAIN MENU” Area and placed my menu items there and then deleted the Sales, Service and Marketing:
This approach results in what feels like a more intuitive user experience to me:
With the user accessing menu items from the MAIN MENU dropdown:
Its going to be interesting to see what sort of Site Map configurations work best in CRM 2013.
