Старый 06.09.2013, 11:11   #1
bojensen: InventTrans Marking in Ax 3.0 via X++
Источник: http://blogs.bojensen.eu/?p=4744
How do you mark 1 line to another using AX 3.0 in X++? I’ve looked through the code using the inventMarking form but can’t quite get it to work via coding. Basically in all my coding examples, the findMovement function within the updateTmpMark doesn’t get called (since I somehow don’t have an _inventTrans). With the [...]
