Старый 26.01.2013, 09:12   #1
emeadaxsupport: AX 2012 R2 for Retail - Setting up discount coupons with bar codes for scanning into POS
Источник: http://blogs.msdn.com/b/axsupport/ar...-into-pos.aspx
The release of R2 for AX 2012 has added 2 new fields (discount code and bar code) to the Discounts form in the Retail module. This now gives us the ability to scan or type in a coupon/discount barcode directly into POS. The steps below are performed on the general Discounts, but the same steps would apply for Mix and Match Discounts and Quantity Discounts. The only difference would be how the items are configured for discounts in the Lines sections of each setup.
1. Set up the bar code masking: Retail > Setup > Bar codes and labels > Bar code mask setup (Example setup)
a. Mask ID = DiscCode
b. Description = Discount Code Bar Code
c. In the Type field, select Discount Code
d. Set up the Masking configurations (Example configuration below)
i. Barcode standard = Code 39
ii. Mask Prefix = 44
iii. Bar code mask segment
1. Type = Discount Code
2. Length = 10
3. Character = T
NOTE: When this barcode is scanned into POS, it uses this prefix and segment to identify the entry as a discount.
2. Set up a specific discount/coupon: Retail > Common > Pricing and Discounts > Discounts
a. Fill in the Discount and Name fields.
b. Enter currency: USD
c. Select a Price Group, or create a new one. (SP 01)
c. Enter a Discount Code (MITT2013)
d. This auto-creates the barcode based on our discount code bar code in step 1 (4400MITT2013)
c. Under Lines click Add
i. Add a product (0017 - Youth Catchers Mitt)
ii. Select a Discount Method = Discount percentage
iii. Enter the amount in the corresponding field. (Discount percentage = 10)
d. Lastly, change the Status to Enabled
e. Close out of the discounts form
3. Add the Price Group to your store: Retail > Common > Retail Channels > Retail Stores
a. Select your store (S0001)
b. Click Price Groups
c. Click New
d. Select the price group used in Step 2.c from the dropdown menu. (SP 01)
4. Sync over your changes: Retail > Periodic > Data Distribution > Distribution Schedule
a. Run the N-1020 (Discount) to sync over the discounts
b. If Step 3 was performed to add the Price Group to the store, then run the N-1070 (Stores and tenders)
5. Log into POS
6. Add item 0017
7. Scan or type in the discount barcode (4400MITT2013)
8. You will see the discount (MITT2013) applied to the line item associated with that discount.
