Старый 10.11.2012, 02:16   #1
ax_gfm_framework_team: Batch processing for dimension set balance rebuilds
Источник: http://blogs.msdn.com/b/ax_gfm_frame...-rebuilds.aspx
When performing dimension set balance rebuilds in a batch, be sure to schedule the batches far enough apart that they do not run concurrently. Doing this will eliminate any chance for contention since a rebuild has to process the entire general journal.
Dimension set balance updates are optimized to run efficiently even if they run concurrently,
