Старый 06.07.2012, 18:11   #1
East Ocean - Technical: How to access Azure WCF Endpoint with CRM plugin
Источник: http://eastoceantechnical.blogspot.c...oint-with.html
CRM plugin only support add service reference on run-time, which means we have to bind and generate the classes using code behind whenever we want to access it.
We can use the following sample code to create the binding in code behind.
BasicHttpBinding myBinding = new BasicHttpBinding();
myBinding.Name = "ARV.MyService";
myBinding.Security.Mode = BasicHttpSecurityMode.None;
myBinding.Security.Transport.ClientCredentialType = HttpClientCredentialType.None;
myBinding.Security.Transport.ProxyCredentialType = HttpProxyCredentialType.None;
myBinding.Security.Message.ClientCredentialType = BasicHttpMessageCredentialType.UserName;
EndpointAddress endPointAddress = new EndpointAddress("http://eea5f8cbdbc749b0bcea2b6250cbae11.cloudapp.net/Myservice.svc");
MyServiceClient client = new MyServiceClient(myBinding, endPointAddress);
client.sendSMS();
