Старый 15.06.2012, 07:03   #1
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Microsoft Dynamics AX 2009 White Paper: BOM Calculation Using Costing Sheet
Overview
The document describes the setup requirements for a costing sheet and includes an overview of how the costing sheet is associated with components such as cost groups, cost categories, and costing versions. The document also contains examples of how the setup affects BOM calculation results. The descriptions are intended to guide you when you set up the application for the calculation of direct and indirect cost on manufactured items.
-ТСЯ или -ТЬСЯ ?
