Старый 17.06.2011, 16:09   #3
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Сообщение от Dark Smile Посмотреть сообщение
To copy the application directory is no solution because the size of it is more than 1 GB.
So what? You can run this once per day: stop AOS, copy current application files to the old subdirectory, start AOS, run a report or something that will scan for changes since the last run (you can automate this ). As to triggers that would allow you to be alerted at the same moment when a changed/created field is saved - there are just no such hooks in the kernel, as far as I know.
