Старый 01.05.2011, 17:13   #1
dax-lessons: Process Industries BUP Layer – Upgrade to Dynamics AX 5.0 SP1 RU6
Источник: http://dynamicsaxgyan.wordpress.com/...x-5-0-sp1-ru6/
Friends, If the customer installation has a hotfix Roll-up(RU) lower than AX2009 SP1 RU-6 , then the environment needs to be upgraded to AX2009 SP1 RU-6 You can download the same from the following link. [Requires partnersource login] Please note: … Continue reading →
