Старый 17.02.2011, 13:07   #4
S.Kuskov is offline
S.Kuskov
3,449 / 1792 (66) ++++++++
AX2009 SP1
SQL Server 2008 R2
static void JobTestLike20110217(Args _args)
//    TableTestLike.Field1 StringSize 10
    TableTestLike TableTestLike;
    Range mask = '*ABC0123456';
    delete_from TableTestLike;
    TableTestLike.clear();
    TableTestLike.Field1 = 'ABC0123456';
    TableTestLike.insert();
    TableTestLike.Field1 = 'ABC012345';
    info(strfmt('mask: %1', mask));
    while select TableTestLike
    where
        TableTestLike.Field1 like mask
        info(TableTestLike.Field1);
