Старый 11.01.2011, 12:49   #3
FE is offline
FE
224 / 58 (2) ++++
Ну, собственно, вот в этой теме как раз есть комментарии от Kees Hertogh:
Kees: It is true that the layered concept already exists in Microsoft Dynamics AX 2009. However there have been a lot of improvements in this area for AX '6'.
One of the biggest improvements, is around enabling ISV solutions to be installed into the same layer, without issue. Before, even with Microsoft Dynamics AX 2009, one would have to manually compare the code from two ISV solutions, then import, 'fixing' the objects so they could work together in the same layer. Now with Microsoft Dynamics AX '6' that is no longer a need.
The model-driven development aspect somewhat exist in Microsoft Dynamics AX 2009, however we have really improved on this, as you and I have talked before. (see: Interview with Microsoft's Kees Hertogh)
With moving the application code, and meta-data of the objects to a SQL Server Database, this opens a whole new world for developers and customers with Dynamics AX '6' around model driven development.
For example, now with a single click, web forms can be generated from rich client forms, with no extra coding needed. This, along with other things will be shown during the keynote of next weeks Dynamics AX 2011 Technical Conference.
