Старый 10.01.2011, 17:11   #1
Dynamics CRM 4.0 Associated View: The New Activity or New Record Dropdown is Not the Easiest Way
Источник: http://www.dynamicscare.com/blog/ind...e-easiest-way/
There are several different ways to create records inside of CRM – well, as you use the CRM application, you’ll find there are several different ways to do just about everything, which can be a bit overwhelming. Fear not – there is always a BEST way to do each (at least in my opinion). In [...]
