Старый 22.12.2010, 16:11   #1
View State & Microsoft Dynamics CRM Custom Webpages
Источник: http://www.dynamicscare.com/blog/ind...stom-webpages/
When you create a custom webpage for Microsoft CRM, sometimes that webpage will contain a control that uses view state to enable server side access.  Everything will work fine in the development environment, but it will not work if you set up the application to use the CRMAppPool App Pool.  Microsoft CRM does not use [...]
