Старый 22.12.2010, 08:11   #1
gurudynamicsax: memory leak in Axapta 3.0
Источник: http://gurudynamicsax.spaces.live.co...FB4E!231.entry
(Problem #1748 Processing some X++ code constructions resulted in a memory leak.)
You may see the same error by creating a job like the following one as it was suggested in Fixlist in order to reproduce the message. I just increased the number of iteration and an info to see the progress.
static void MemoryLeakTest(Args _args)
container custcont;
int loop;
Custtable custtable;
select custtable;
custcont = conins(custcont,1,custtable.data());
for(loop = 1; loop
