Старый 15.12.2010, 23:11   #1
Dynamics CRM Tools: Tools Update: IsvConfigManager and FormJavaScriptManager
Источник: http://mscrmtools.blogspot.com/2010/...nager-and.html
That will surely be the last update for these tools (unless you discover a bug ).
Isv Config Manager changelog:
  • Remove publishing feature (Isv.config doesn’t require publish)
  • Add Expand/Collapse feature
  • Add Read/Write Xml : You can now see what is the corresponding Xml for a treeview element. You can also add a treeview element by pasting xml content.
Form JavaScript Manager changelog:
  • Ability to load script files from a directory AND all its sub directories
  • When opening again the folder browser, it starts from the current selected folder
As usual, you can download these new versions using the right hand pane of this blog.
