Старый 09.12.2010, 18:08   #4
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
Сообщение от ist Посмотреть сообщение
Maybe I have not explained properly. I want to choose a value from the date lookup, then write '..' and then select the second value from the date lookup.
Usually this works fine: 01.01.2010..31.12.2010.
Maybe AX is stuck on the strange date format you have: YYYY.MM.DD.
What weird country are you from?
