Старый 19.11.2010, 01:02   #1
Dicora is offline
Dicora
Если запустить этот скрипт без конфига вообще получаем такую ошибку:
Microsoft CRM Error Report:
Error Description:
CS1513: } expected
Error Details:
c:\Program Files\Microsoft Dynamics CRM\CRMWeb\Files\notes.aspx(19): error CS1513: } expected
Full Stack:
[HttpCompileException: c:\Program Files\Microsoft Dynamics CRM\CRMWeb\Files\notes.aspx(19): error CS1513: } expected]
   at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath)
   at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
   at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
   at System.Web.Compilation.BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean noAssert)
   at System.Web.Compilation.BuildManager.CreateInstanceFromVirtualPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp, Boolean noAssert)
   at System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)
   at System.Web.UI.PageHandlerFactory.System.Web.IHttpHandlerFactory2.GetHandler(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)
   at System.Web.HttpApplication.MapHttpHandler(HttpContext context, String requestType, VirtualPath path, String pathTranslated, Boolean useAppConfig)
   at System.Web.HttpApplication.MapHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
   at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Other Message:
Error Number:
Source File:
Line Number:
19
Date: 11-19-2010
Time: 01:00:58
Server: crmsrv02
Request URL:
http://crmsrv02:5555/Files/notes.aspx?guid={07A71E60-2EF3-DF11-BB70-003048BE732D}
т.е. в папке Files
веб конфиг отсутствует.
в чем ошибка подскажите пожалуйста.
Было бы очень хорошо отладить этот скрипт чтобы не придумывать решение проблемы с нуля.
