Старый 08.09.2009, 11:05   #1
mscrm4ever: CRM 4.0 Changing Tab Order
Источник: http://mscrm4ever.blogspot.com/2009/...tab-order.html
A while back i posted a solution for changing vertical tabbing to horizontal tabbing. The code ran a bit slow with lookups and so the code below is a revision of the previous posting with the fix.
function OnCrmPageLoad()
ReArangeTabIndex();
function ReArangeTabIndex()
for( var i = 0 ; i < crmForm.all.length ; i++ )
var element = crmForm.all[ i ];
if (element.tabIndex)
if (element.className == "ms-crm-Hidden-NoBehavior" || element.tagName == "A")
continue;
element.tabIndex = 1000 + (i*10);
OnCrmPageLoad();
