Сообщение от
kashperuk
Вроде когда-то слышал, что это нарушает соглашение какое-то.
Правда?
Ага, где-то в соглашении есть "нельзя менять бинарники".
MICROSOFT SOFTWARE LICENSE TERMS
MICROSOFT DYNAMICS AX 4.0
4. ADDITIONAL LICENSING REQUIREMENTS AND/OR USE RIGHTS.
f. Modification. You may modify the software only as necessary to use it if you received it in source code form or you have licensed tools from Microsoft that allow you to modify the object code form. You agree that Microsoft is not responsible for any problems that result from modifications made by you or a third party or that are caused by third party hardware or software.
6. SCOPE OF LICENSE.
You may only use the software for your internal business purposes. You may not
• work around any technical limitations in the software;
• reverse engineer, decompile or disassemble the software, except and only to the extent that applicable law expressly permits, despite this limitation;
• make more copies of the software than specified in this agreement or allowed by applicable law, despite this limitation;
Но, вообще говоря, ресурсы из почти любого екзешника вытаскиваются и заменяются подобным образом.
