Тема
Переход на КР2 + Analysis 2005
11.08.2008, 14:41
4
egorych
154
7
Сообщение от
CasperSKY
"The peer prematurely closed the connection." - с чем может быть связана ?
Может это поможет -
http://forums.microsoft.com/TechNet/...9362&SiteID=17
SSAS does not support SQL logins so this will not work. It only supports windows logins and your login would either need to be in the server administrators role (where you would be able to see everything) or your login would need to be added to a role in the database with rights to see specific cube.
This article has information on resolving connection issues.
http://www.microsoft.com/technet/pro...L2005ASCS.mspx
but you get the "transport layer" issue when trying to connect from a non trusted domain.
egorych
Посмотреть профиль
Отправить личное сообщение для egorych
Найти ещё сообщения от egorych
