Старый 12.06.2008, 23:06   #1
JOPX: Musings about Microsoft Dynamics AX 2009
Источник: http://jopx.blogspot.com/2008/06/mus...namics-ax.html
I did a practice session about integrating Microsoft Office SharePoint Server 2007, Microsoft Dynamics AX 2009 and the Business Intelligence capabilities of Microsoft SQL Server a couple of weeks ago.
I'm mostly a SharePoint guy but I  was pretty impressed with the capabilities of Microsoft Dynamics AX 2009. Since Dynamics AX 2009 finally RTM'ed (Download on partnersource - https://mbs.microsoft.com/partnersou...009release.htm
For more info check out these links:The coolest thing for SharePoint developers is probably the ASP.NET based Enterprise Portal - everything is basically an ASP.NET web part which makes it a lot easier to develop a light-weight web access for your Dynamics AX back-end.
Something which still strikes me as odd though is the fact that almost all of the documentation is partner-access only - so you will need a Partnersource logon to take a look at the most interesting bits of info. I truly believe that the key to the success of a platform is the community which drives it  ... and it seems as if the Dynamics AX platform solely relies on its partner platform. Too bad ... [This is my personal opinion and not necessarily this of my employer]
Tags van Technorati: microsoft,dynamics+ax,axapta,axapta+2009
