Старый 12.04.2007, 16:10   #1
Dave: XML File Size limitation using FindList AIF Actions
Источник: http://daxdave.blogspot.com/2007/03/...-findlist.html
If you develop a findList Action in AX AIF and your dataset is going to be bigger than about 3MB, you will need to follow some steps within the AX 4.0 release notes. Search through it and find and execute the steps to add/modify the 'maxbuffersize' registry key.
