Старый 29.03.2022, 07:14   #1
erconsult: D365 Electronic Reporting: JOIN records in pairs
Источник: https://erconsult.eu/blog/electronic...join-in-pairs/
<div data-elementor-type="wp-post" data-elementor-id="6683" class="elementor elementor-6683" data-elementor-settings="[]"> <div class="elementor-section-wrap"> <div class="elementor-container elementor-column-gap-default"> <div class="elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-b53689d" data-id="b53689d" data-element_type="column"> <div class="elementor-widget-wrap elementor-element-populated">
<div class="elementor-element elementor-element-65ba7c0 elementor-widget elementor-widget-text-editor" data-id="65ba7c0" data-element_type="widget" data-widget_type="text-editor.default"> <div class="elementor-widget-container"> Recently, I came across a really challenging requirement in Electronic Reporting / Configurable Business Documents in Dynamics: in an additional section in the Delivery note, print a flat table where every pair of consecutive records becomes one line:
NoNot like thisBut like thisNo1Left laceLeft lace – Right lace12Right laceLeft shoe – Right shoe23Left shoe4Right shoeThis required a set of sophisticated techniques I am thrilled to share. The idea is to split into odd and even records and build something like
SELECT *, ROW_NUMBER as Rn1 FROM Records JOIN *, ROW_NUMBER as Rn1 from Records ON Rn2= Rn1+1
<ol>Enumerate: make a so called Calculated field at the ER configuration’s root level with a record list and a row Number inside:
ENUMERATE(ALLITEMS(MyRecords))Add another Calculated field at the row level to check if the current record has an odd or an even row number: LEN(REPLACE("13579",RIGHT(NUMBERFORMAT(@.Number,"#"),1),"",false))
erconsult: Electronic Reporting (ER) Cookbook 4: References in a model Blog bot DAX Blogs 0 04.12.2020 06:14
erconsult: Number of records in D365 Blog bot DAX Blogs 0 29.08.2020 05:11
patrickmouwen: How to Unlock Many Hidden D365 Retail Features! Blog bot DAX Blogs 0 13.05.2020 22:13
erconsult: Electronic reporting for data migration Blog bot DAX Blogs 4 17.01.2020 17:32
erconsult: Electronic Reporting (ER) Cookbook 2: new tips from the kitchen Blog bot DAX Blogs 0 06.08.2018 17:11
Часовой пояс GMT +3, время: 03:07.
