Старый 22.03.2018, 02:58   #61
ax_mct is offline
ax_mct
Banned
2,548 / 1091 (0) ++++++++
p. 72
Lifecycle Services: Telemetry-based KB recommendation
LCS has been extended to include telemetry-driven KB recommendations to customers. The goal of this functionality is to help us understand the extent to which hotfixes have solved an issue and to proactively push out hotfixes to customers. This will allow customers to spend less time looking for solutions to issues that a hotfix already exists for. In addition, it will provide telemetry that gives us better insight into which fixes have solved specific customer issues. This enhancement also lets us ship additional telemetry to gain additional insight where needed. The first example of telemetry-based KB recommendations is the Critical X++ updates tile.
Critical X++ updates are hotfixes that we recommend based on the telemetry data from your production environment. These updates are specific to your production environment and can be downloaded only from your production environment.
To test and apply critical X++ updates, you should first download the updates from the production environment, and then apply them in a development environment, build a deployable package, and then deploy and test it in your sandbox environment. After it's fully tested, you can then deploy it to your production environment.
Выражение "proactively push out hotfixes to customers" (на основании телеметрии) интересно.
Если я правильно понял они таки сами не применяют хотфиксы прямо на PROD, но предлагают оттуда скачивать. То есть "proactively push out hotfixes to customers" скорее всего означает мы делаем вам предложение, а не устанавливаем за вас.
Последний раз редактировалось ax_mct; 22.03.2018 в 03:08. Причина: чушь написал
Старый 22.03.2018, 12:12   #62
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2155 (80) +++++++++
Я так понял, да. Т.е. находится типовая ошибка под которою заведен KB и в отдельный список на LCS выводится. В целом хорошая тема. Вопрос насколько она точно будет попадать в точку, сейчас не так часто встретишь хорошую однозначную ошибку.
Ivanhoe as is..
Старый 28.03.2018, 19:17   #63
trud is offline
trud
1,038 / 1629 (57) ++++++++
Записей в блоге: 1
Тут есть немного про кастомные поля: http://download.microsoft.com/downlo...5_03192018.pdf
И наконец-то вернули Alerts.
О, зато какую тему сделали "One voucher deprecation". т.е. они хотят запретить возможность ввода нескольких строк в журнал ГК с одним ваучером.
Это была просто стопроцентная тема понять при кодеревью хороший код или нет, если кто-то зашивался в коде на то что ваучер уникальный
https://docs.microsoft.com/en-us/dyn...er/one-voucher
Старый 28.03.2018, 19:52   #64
Logger is offline
Logger
3,875 / 3123 (112) ++++++++++
Записей в блоге: 2
А как же сложные (многострочные) проводки в западном учете вводить ?
Старый 28.03.2018, 20:46   #65
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1849 (69) ++++++++
Нормальные проводки - так же как и раньше
The existing functionality for financial journals (general journal, fixed asset journal, vendor payment journal, and so on) lets you enter multiple subledger transactions in the context of a single voucher. We refer to this functionality as "One voucher."
Мне на прошлой неделе показали в 2012 ваучер с пятью (вроде) клиентами и парой поставщиков разнесенный из общего журнала ГК. Спрашивать "Зачем?" - бесполезно. Потому что могли Вот подобное гуано можно будет запретить на уровне конфигурации
-ТСЯ или -ТЬСЯ ?
Последний раз редактировалось Vadik; 29.03.2018 в 21:07.
Старый 29.03.2018, 03:27   #66
trud is offline
trud
Записей в блоге: 1
Да, вводить кстати пока не запрещают(в некоторых случаях это нужно), а просто говорят что это deprecation. т.е. это по сути означает что нельзя будет создавать запросы на поддержку(и я так понял могут неправильно работать PowerBI отчеты и всякие импорты где связка идет по ваучеру в модели данных)
вообще конечно это что-то новое в поддержке, объявление устаревшим целого пласта функциональности без конкретных альтернатив . довольно изящно с точки зрения менеджмента.
Старый 29.03.2018, 11:42   #67
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Вот именно. Одно дело настройка, другое дело отказ от функциональности. Плохое решение. Сколько еще таких сюрпризов нас ждёт...
Ivanhoe as is..
Старый 29.03.2018, 12:24   #68
Vadik is offline
Vadik
Аватар для Vadik
Мне как человеку не начавшему еще работать с 8.0 трудно понять о каком отказе от функциональности идет речь (пока вроде на уровне журнала настраивается), а также какие проблемы, кому и когда это создаст, поэтому я просто файлик тут подвешу
Тип файла: docx Breaking change_One voucher_FINAL.docx (183.5 Кб, 110 просмотров)
-ТСЯ или -ТЬСЯ ?
За это сообщение автора поблагодарили: trud (2).
Старый 29.03.2018, 13:05   #69
trud is offline
trud
Записей в блоге: 1
Я так понял с точки зрения кода изменений вообще ноль, т.е. отказываются именно от концепции одного ваучера(если надо можно пользоваться).
т.е. они скорее всего написали кучу BI отчетов или форм где идут join по ваучеру-дате, естественно эти отчеты стали задваивать данные и кто-то пожаловался
Остается только восхищаться менеджерскими способностями Kristi Weekley(17 лет работы в мс судя по лингедину) которая без единой строчки кода смогла решить проблему
Старый 29.03.2018, 13:58   #70
fed is offline
fed
Аватар для fed
2,893 / 5650 (194) ++++++++++
Вообще-то они там еще написали что у них скидки про сопоставлениях иногда отваливаются, если несколько клиентских или поставщицких проводок с одним номером ваучера проходят. И мне кажется, я на эту багу натыкался ажно в версии 3.0. При этом старую дамгаардовскую логику поставлений рефакторили, но функционально только расширяли, а не переписывали....
Старый 29.03.2018, 14:01   #71
Vadik is offline
Vadik
Аватар для Vadik
В общем, начальник задумчиво посмотрел на девушку и волевым решением выдал Наташе подтяжки
-ТСЯ или -ТЬСЯ ?
Последний раз редактировалось Vadik; 29.03.2018 в 14:05.
За это сообщение автора поблагодарили: belugin (5).
Старый 29.03.2018, 18:10   #72
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Из яммера
Based on feedback on the document, I wanted to add the following clarification:
IMPORTANT: Please note that we are NOT removing the option 'One voucher number only' from the Journal name setup. This option is still supported when the voucher only contains Ledger account types. Customers must be careful, though, in using this setting because the voucher will not post if they use One voucher number only but then enter more than one customer, vendor, bank, fixed asset, or project. Also, customers can still enter a mix of these subledger account types, such as a payment within a single voucher that contains account types of Vendor/Bank.
d365o
kurthatlevik: A Practical Guide for Dynamics 365 Iterative Implementation Blog bot DAX Blogs 0 15.09.2017 01:21
kurthatlevik: New Microsoft Dynamics AX – A guide for using retail sales prices and discounts Blog bot DAX Blogs 0 01.12.2015 18:12
kurthatlevik: Dynamics AX 2012 – Great share on retail Blog bot DAX Blogs 0 28.10.2015 20:11
kurthatlevik: Turn your Dynamics AX WMS from ‘Where’s My Stuff’ to an actual ‘Warehouse Management System’ Blog bot DAX Blogs 0 21.11.2013 19:11
Часовой пояс GMT +3, время: 03:33.
