22.03.2018, 16:11 | #1 |
axtoday: Setup an external catalogue for PunchOut eProcurement
Источник: http://axtoday.blogspot.com/2018/03/...-punchout.html
============== D365O has a functionality to do PunchOut eProcurement. The main idea is not having to maintain the vendor item numbers in your system as well as always having the latest information on the vendor items. Read more in here https://docs.microsoft.com/en-us/dyn...g-for-punchout The steps needed to set this up:
Once you’ve done all that, in the purchase requisition form, you can click the “External catalogues” button on the line section, which will open a dialog where you can choose which vendor’s website that you want to open (based on the configuration that you’ve done on the external catalogues form). When you click the button, you will get a prompt that says that you will now be redirected to an external site, and after you click OK, you should see the vendor’s website. You can then place items into the shopping basket, and when you have completed the check out, it will take you back to D365O which gives you the chance to review the order. You can remove lines that you don’t need, or you can choose a different procurement category if needed. When you click the Add to requisition button at the bottom of the page, it will then transfer the lines into the purchase requisition. Few important notes:
