16.11.2018, 16:11 | #1 |
d365technext: Compare Records D365FO & AX 2012
Источник: http://d365technext.blogspot.com/201...o-ax-2012.html
============== How to compare two records buffer field to field. publicstaticcontainer compareRecords(Common _record1, Common _record2) { SysDictTable dictTable =new SysDictTable(_record1.TableId); SysDictField dictField; FieldId fieldId, extFieldId; container ret; int i, j; ; if(_record1.TableId!= _record2.TableId) returnconNull(); for(i=1; i<=dictTable.fieldCnt(); ++i) { fieldId = dictTable.fieldCnt2Id(i); dictField =new SysDictField(_record1.tableId, fieldId); if(!dictField.isSystem()) { for(j=1; j<= dictField.arraySize(); ++j) { extFieldId = fieldId2Ext(fieldId, j); if(_record1.(extFieldId)!= _record2.(extFieldId)) { ret +=[extFieldId, _record1.(extFieldId), _record2.(extFieldId)]; } } } } return ret; } For Demo purpose you can use below code in job/runnable class. static void demoCompareRecords(Args _args) { VendTable vendTable_1 = VendTable::find('ABC'); VendTable vendTable_2 = VendTable::find('XYZ'); container con; int i; ; con = MyClass::compareRecords(vendTable_1 , vendTable_2 ); for (i=1; i
