Старый 14.11.2017, 09:11   #1
25,475 / 846 (79) +++++++
crmtipoftheday: Tip #1021: Everything is an app
Источник: https://crmtipoftheday.com/1021/everything-is-an-app/
If you provisioning a trial and accidentally or deliberately missed the checkboxes enabling Customer Service, you will end up with Dynamics 365 instance with the “facelifted” Web UI but nothing else. Where’s the much tooted Universal User Interface (UUI) that was meant to replace Interactive Service Hub in the version 9? Well, it’s simply not installed.
One thing to remember that, in the new world, everything is either an app or a solution. Which is also an app but a “first-class” app, accessed via administration center. If you are craving to explore UUI:
  • Open Dynamics 365 Administration Center (https://port.crmX.dynamics.com/G/Ins...ncePicker.aspx)
  • Select your instance
  • Click little pencil icon next to Solutions
  • Select Customer Service Hub, click Install
  • Have a cup/can/bottle of a hot/cold beverage of your choice
  • Open your instance, click on Dynamics 365 on the top
Enjoy exploring it. Accidentally, that’s the only way to access Knowledge Articles.
crmtipoftheday: Tip #1019: Understand decimal precision in Dynamics 365 Blog bot Dynamics CRM: Blogs 0 09.11.2017 08:14
crmtipoftheday: Tip #1018: Automatically create Dynamics 365 records from Social Engagement Blog bot Dynamics CRM: Blogs 0 08.11.2017 18:11
crmtipoftheday: Tip #1016: App Designer and disabled sitemap subareas in Dynamics 365 Blog bot Dynamics CRM: Blogs 0 06.11.2017 10:12
crmtipoftheday: Tip #1007: What is the Common Data Service (CDS) today? Blog bot Dynamics CRM: Blogs 0 23.10.2017 19:12
Часовой пояс GMT +3, время: 02:01.
