Старый 14.09.2017, 13:11   #1
25,475 / 846 (79) +++++++
domhk: Use PowerShell and Business Connector to retrieve data from Dynamics AX (AX2009) - Part 2
Источник: http://domhk.blogspot.com/2015/11/us...nector_20.html
In my last post I mentioned the reason I use Powershell to draw data from AX. What I want to achieve is ease of drawing data from AX and the ability to save and re-run queries. I wrote a basic script module to do this.
The main utility from the module is a new cmdlet New-AXSelectStmt. It is used to pass X++ select statement to AX and get a list of PSObject as return.
A simple example would be:
New-AXSelectStmt CustTable -stmt "SELECT * FROM %1"
It is also possible to run select statement with multiple tables:
New-AXSelectStmt SalesTable,SalesLine -stmt "SELECT * FROM %1 JOIN %2 WHERE %1.SALESID == %2.SALESID" -top 50
In terms of actual usage, I have a case where a user's ask about the net weight shown on an invoice. In the invoice printout, a line of 10pcs is shown to weight 0.197g. However, on the item details form the net weight per piece is 0.02. The user thinks there is an error.
I used the query below to quickly check the actual net weight stored in the database and show user what happened.
New-AXSelectStmt InventTable -stmt "SELECT * FROM %1 WHERE %1.ItemId == 'itemid'" -fieldLists "ItemId,NetWeight,ItemNAme,ItemGroupId" -showLabel
In addition, after getting the return result I am able to do all sorts of thing. I can write scripts for scheduled run, I can also:
# Export the result to a csv
New-AXSelectStmt CustTable -stmt "SELECT * FROM %1" -top 10 | Export-CSV "C:\Temp\custList.csv"
# Email the exported file
Send-MailMessage -From $mailFrom -To $mailTo -Subject $subject -Body $body -Attachments "C:\Temp\custList.csv" `
-SmtpServer $SMTPServer -Port $SMTPPort -Credential $mycreds -BodyAsHtml -UseSsl -Attachment
Well, that's all! Happy DAXing...until next time. =]
stephenmann: Technical History of Dynamics AX - From Axapta 3.0 to AX2012 Blog bot DAX Blogs 5 03.03.2017 10:22
jaestevan: PowerShell para la administración automática de Dynamics AX 2012 (PS-II) Blog bot DAX Blogs 0 28.06.2016 17:11
NAV Team: Upgrade Toolkit for Upgrading Data from Microsoft Dynamics NAV 2009 R2 and Microsoft Dynamics NAV 2009 SP1 to Microsoft Dynamics NAV 2013 R2 Blog bot Dynamics CRM: Blogs 0 22.11.2013 20:00
Часовой пояс GMT +3, время: 19:08.
