06.07.2017, 06:15 | #1 |
waldo: Create an offline Development Preview – enable the in-client visual designer
Источник: https://dynamicsuser.net/nav/b/waldo...isual-designer
============== You might remember this post: http://www.waldo.be/2017/02/20/make-...local-machine/ Well, back in those days, I might have forgotten a few bits ;-). Namely to enable the in-client visual designer. Well, there is not much to it – you can simply edit the web.config-file, and add the designer-attribute in it.. . With PowerShell, you can do it with: Код: $NAVWebConfigFile = "C:\inetpub\wwwroot\Navision_main\Web.config" $NAVWebConfig = [xml](Get-Content $NAVWebConfigFile) $designerKey = $NAVWebConfig.SelectSingleNode("//configuration/DynamicsNAVSettings/add[@key='designer']") if ($designerkey) { $designerkey.value = "true" } else { $addelm = $NAVWebConfig.CreateElement("add") $keyatt = $NAVWebConfig.CreateAttribute("key") $keyatt.Value = "designer" $addelm.Attributes.Append($keyatt) | Out-Null $valatt = $NAVWebConfig.CreateAttribute("value") $valatt.Value = "true" $addelm.Attributes.Append($valatt) | Out-Null $NAVWebConfig.configuration.DynamicsNAVSettings.AppendChild($addelm) | Out-Null } $NAVWebConfig.Save($NAVWebConfigFile) So, what are the steps again to create a local environment from this wonderful “New Developer Preview”? This is what I would suggest:
Sure .. If you like to click al lot – you can do this quite manually as well. I suggest you look at the video that Mark just created. Источник: https://dynamicsuser.net/nav/b/waldo...isual-designer
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось mazzy; 06.07.2017 в 12:03. |
