Старый 10.04.2023, 00:15   #1
25,475 / 846 (79) +++++++
Two outer joined tables in a report without duplicates from both sides
Источник: http://alexvoy.blogspot.com/2023/04/...in-report.html
I cannot find a particular term for this type of join; so I called it 'hanging left outer join'.
Let's state the problem.
We have two tables:
- LedgerJournalTrans (trans) with a field mgcProjId, which is a reference to ProjTable.
- mgcWarrantsDetails (details), which may have 0..N records for certain records from ProjTable.
Examples of data in both may look like the following:
If we apply standard outer join, the output will be as follows
But we need to print all details records by 'hanging' them against the same projId, like this
So, no duplicates from both tables must be present in the merged table.
This is how you can achieve it.
/// /// Process report data. /// public void processReport() { Query query; QueryRun qr; mgcWarrantsDetails details; LedgerJournalTrans trans; ProjId prevProjId; // merge trans and detail even if details are empty void insertWithTrans() { mgcProjWarrantDetailTmp.clear(); mgcProjWarrantDetailTmp.RefRecId = trans.RecId; mgcProjWarrantDetailTmp.JournalNum = trans.JournalNum; mgcProjWarrantDetailTmp.TransDate = trans.TransDate; mgcProjWarrantDetailTmp.Voucher = trans.Voucher; mgcProjWarrantDetailTmp.ProjId = trans.mgcProjId; mgcProjWarrantDetailTmp.WarrantDetailId = details.WarrantDetailId; mgcProjWarrantDetailTmp.WarrantsWithPrice = details.WarrantsWithPrice; mgcProjWarrantDetailTmp.insert(); } // merge empty trans and detail; it will be 'a hanging' detail void insertWarrants() { mgcProjWarrantDetailTmp.clear(); mgcProjWarrantDetailTmp.ProjId = details.ProjId; mgcProjWarrantDetailTmp.WarrantDetailId = details.WarrantDetailId; mgcProjWarrantDetailTmp.WarrantsWithPrice = details.WarrantsWithPrice; mgcProjWarrantDetailTmp.insert(); } // process warrants for the previous projId // 'hanging' details on the right side of the report void processRestOfWarrants() { // if there are still some warrants we found for the previous projId if (details) { // as we do not have enough rows from trans with the same previous projId, // let's add them with empty part from trans side next details; while(details) { insertWarrants(); next details; } } } // Get the query from the runtime using a dynamic query. query = this.parmQuery(); qr = new QueryRun(query); // we suppose that trans sorted by projId // each projId may have 0..N of warrants (details) while(qr.next()) { // get next transaction trans = qr.get(tablenum(LedgerJournalTrans)); // projId changes if(prevProjId != trans.mgcProjId) { // if there are still some warrants we found for the previous projId processRestOfWarrants(); // get the first warrant for the new projId select details where details.ProjId == trans.mgcProjId; // keep the new as a previous for the next iteration prevProjId = trans.mgcProjId; } // if this is a trans with the same projId, then we can merge it with the next warrant else if (details) { next details; } // merge trans with warrants insertWithTrans(); } // if there are still some warrants we found for the previous projId processRestOfWarrants(); }
Raw outer joined data
Ascending ProjId
Descending ProjId
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
saveenr: The Keynote SSRS report from the AX Technical Conference Blog bot DAX Blogs 0 12.02.2011 00:11
Часовой пояс GMT +3, время: 11:51.
