Старый 03.01.2017, 22:12   #1
25,475 / 846 (79) +++++++
emeadaxsupport: Work with Financial dimensions [AX2012, X++]
Источник: https://blogs.msdn.microsoft.com/axs...ions-ax2012-x/
NOTES: All codes in this document based on CU12. Disclaimer: All the programming examples in this article are for illustration purposes only. Microsoft disclaims all warranties and conditions with regard to use of the programming example for other purposes. Microsoft shall not, at any time, be liable for any special, direct, indirect or consequential damages,... Read more
emeadaxsupport: Using financial dimensions with Lean manufacturing Blog bot DAX Blogs 0 08.12.2015 03:18
DynamicsAxSCM: WHS Work List Blog bot DAX Blogs 0 19.06.2015 15:11
emeadaxsupport: Error during data import, when using multiple entities in one Processing Group that have different financial dimensions Blog bot DAX Blogs 0 26.11.2014 20:11
sumitax: AX2012 Features – Financial Dimensions changes Blog bot DAX Blogs 0 12.05.2011 15:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 16:51.
