31.10.2016, 09:11 | #1 |
organicax: Quick import export
Источник: https://organicax.com/2016/10/30/quick-import-export/
============== If you are looking for a quick way to dump out some data from AX and you have a current CU then you will find the quick import export. This allows you to use a sample file based on the entity you want to export from. It will save you creating a processing group, although you have the option of saving a processing group. Here is a quick overview. AX2012 R3 CU11 Cheers Lachlan Filed under: Data migration Источник: https://organicax.com/2016/10/30/quick-import-export/
