24.10.2016, 17:11 | #1 |
organicax: Vendor invoice approved by purchase order preparer modification
Источник: https://organicax.com/2016/10/24/ven...-modification/
============== In a previous post we had a look at the walk through using a new participant provider for the vendor invoice workflow. In this overview we’ll have a look at the objects we modified to make this work. It is work following a step by step example of creating a participant provider which you can follow in this post. Here is a quick overview. AX2012 R3 CU11 If you want a copy of the XPO for the sample code you can find it on my one drive. https://1drv.ms/u/s!AjyKH96OSFD9gRCdwNGk7lrwlxS1 Cheers Lachlan Filed under: Accounts payable Источник: https://organicax.com/2016/10/24/ven...-modification/
