Старый 19.03.2016, 15:11   #1
25,475 / 846 (79) +++++++
axinthefield: AOT Find tool – old but useful
Источник: https://blogs.msdn.microsoft.com/axi...ld-but-useful/
I was looking for a certain pattern in the code, using the AOT Find-tool. There is an option to use “Filter”, which will then run a validation function like : boolean filterMethod(str _treeNodeName, str _treeNodeSource, XRefPath _path, ClassRunMode _runMode) { %1 } where the %1 will be replaced with your filter text to form a...
How to find in AOT all objects named like... Blog bot DAX Blogs 0 25.09.2014 01:24
bojensen: How to find All USR Layer Elements in AOT Blog bot DAX Blogs 0 15.05.2014 19:11
How to find your object in AOT projects Blog bot DAX Blogs 0 03.05.2011 06:15
To find objects in AOT with particular properties Blog bot DAX Blogs 1 26.04.2008 07:33
daxmy: AOT Find function Blog bot DAX Blogs 0 17.08.2007 01:23
Часовой пояс GMT +3, время: 08:09.
