Старый 19.02.2016, 08:12   #1
25,475 / 846 (79) +++++++
emeadaxsupport: Timesheet periods have not been created for employee..
Источник: https://blogs.msdn.microsoft.com/axs...-for-employee/
Occasionally when you want to add a new Project Timesheet you might run into the following error message ‘Timesheet periods have not been created for:employee’ To overcome this message and create the timesheet you can apply this procedure In this case I will assign Tim Litton to the period type ‘EmplWeekly’. In Human Resources\Workers\ I... Read more
emeadaxsupport: Microsoft Dynamics AX 2012 Upgrade – Using the State Transfer Tool with AX 2009, you can potentially have duplicate records created within table Shadow_DirPartyRelationship Blog bot DAX Blogs 0 23.04.2015 02:19
emeadaxsupport: AX 2012 R2 for Retail - Using advanced discount periods with discounts that have start and end times around 12am. Blog bot DAX Blogs 0 06.01.2014 19:11
emeadaxsupport: Purchase Requisition Workflow in Dynamics AX 2009 fails with Stopped (error): Work item could not be created. Insufficient rights for user Blog bot DAX Blogs 0 18.11.2010 21:12
emeadaxsupport: Warning when loading license file - License value for ID 2024 has not been created (or License value for ID 2025 has not been created) Blog bot DAX Blogs 0 12.01.2010 04:44
Часовой пояс GMT +3, время: 13:15.
