01.09.2016, 01:18 | #1 |
organicax: Default production finished goods location must be set.
Источник: https://organicax.com/2016/08/31/def...n-must-be-set/
============== If you are using the WMS RF device menus with production and using the Report as Finished or the Report as finished and putaway menu. If you get the message “Default production finished goods location must be set.” this is likely a result of not having specified the default parameter on the warehouse for the location. Here is a quick overview. AX2012 R3 CU10. Cheers Lachlan Filed under: Production control, Warehouse management Источник: https://organicax.com/2016/08/31/def...n-must-be-set/
