Старый 18.08.2020, 16:11   #1
25,475 / 846 (79) +++++++
waldo: Using DevOps Agent for prepping your Docker Images
Источник: https://dynamicsuser.net/nav/b/waldo...-docker-images
I have yet another option for you that might be interesting for you to handle the artifacts that Microsoft (Freddy) is providing in stead of actual Docker Images on a Docker Registry.
What changed?
Well, this shouldn’t be new to you anymore. You must have read the numerous blogposts from Freddy announcing a new way of working with Docker. No? You can find everything on his blog.
Let me try to summarize all of this in a few sentences:
Microsoft can’t just keep providing you the Docker images like they have beein doing. With all the versions, localizations .. and mainly the countless different hosts (Windows Server, Win 10, Windows updates – in any combination) .. Microsoft simply wasn’t able to upkeep a stable and continuous way to provide all the images to us.
So – things needed to change: in stead of providing images, Microsoft is now providing “artifacts” (let’s call them “BC Installation Files”) that we can download and use to build our own Docker images. So .. long story short .. we need to build our own images.
Now, Freddy wouldn’t be Freddy if he wouldn’t make it as easy as at all possible for us. We’re all familiar with NAVContainerHelper – well, the same library has now been renamed to “BcContainerHelper”, and contains the toolset we need to build our images.
What does this mean for DevOps?
Well – lots of your Docker-related pipelines were probably going to download an image, and using that image to build a container. In this case, you’ll not download an image, but simply see if it already exists. And if not, build an image, and afterwards build a container from it, which you can use for your build pipeline in DevOps.
Now, while BCContainerHelper has a built in caching-mechanisme in the “New-BCContainer” cmdlet .. I was trying to find a way to have stable build-timings .. together with “not having to build an image during a build of AL code”. And there is a simple solution for that…
Schedule a build pipeline to build your Docker Images at night
Simple, isn’t it :-). There are only a few steps to take into account:
  1. Build a yaml that will build all images you need
  2. Create a new Build pipeline based on that yaml
  3. Schedule it every night (or every week – whatever works for you)
As an example, I built this in a public DevOps project where I have a few DevOps examples. Here are some links:
The yaml
Obviously, the yaml is the main component here. And you’ll see that I made it as readable as possible:
name: Build Docker Imagespool: WaldoHetznervariables:  - group: Secrets  - name: DockerImageName.current    value: bccurrent  - name: DockerImageName.insider    value: bcinsider  - name: DockerImageSpecificVersion    value: '16.4'  - name: DockerArtifactRetentionDays    value: 7steps:# Update BcContainerHelper- task: PowerShell@2  displayName: Install/Update BcContainerHelper  inputs:    targetType: 'inline'    script: |      [System.Net.ServicePointManager]::SecurityProtocol = [System.Net.ServicePointManager]::SecurityProtocol -bor [System.Net.SecurityProtocolType]::Tls12      install-module BcContainerHelper -verbose -force      Import-Module bccontainerhelper- task: PowerShell@2  displayName: Flush Artifact Cache  inputs:    targetType: 'inline'    script: |      Flush-ContainerHelperCache -cache bcartifacts -keepDays $(DockerArtifactRetentionDays)# W1- task: PowerShell@2  displayName: Creating W1 Image  inputs:    targetType: 'inline'    script: |      $artifactUrl = Get-BCArtifactUrl      New-BcImage -artifactUrl $artifactUrl -imageName $(DockerImageName.current):w1-latest# Belgium specific version- task: PowerShell@2  displayName: Creating BE Image  inputs:    targetType: 'inline'    script: |      $artifactUrl = Get-BCArtifactUrl -country be -version $(DockerImageSpecificVersion)      New-BcImage -artifactUrl $artifactUrl -imageName $(DockerImageName.current):be-$(DockerImageSpecificVersion)# Belgium latest- task: PowerShell@2  displayName: Creating BE Image  inputs:    targetType: 'inline'    script: |      $artifactUrl = Get-BCArtifactUrl -country be      New-BcImage -artifactUrl $artifactUrl -imageName $(DockerImageName.current):be-latest# Belgium - Insider Next Minor- task: PowerShell@2  displayName: Creating BE Image (insider)  inputs:    targetType: 'inline'    script: |      $artifactUrl = Get-BCArtifactUrl -country be -select SecondToLastMajor -storageAccount bcinsider -sasToken "$(bc.insider.sasToken)"      New-BcImage -artifactUrl $artifactUrl -imageName $(DockerImageName.insider):be-nextminor# Belgium - Insider Next Major- task: PowerShell@2  displayName: Creating BE Image (insider)  inputs:    targetType: 'inline'    script: |      $artifactUrl = Get-bcartifacturl -country be -select Latest -storageAccount bcinsider -sasToken "$(bc.insider.sasToken)"      New-BcImage -artifactUrl $artifactUrl -imageName $(DockerImageName.insider):be-nextmajor# Images- task: PowerShell@2  displayName: Docker Images Info  inputs:    targetType: 'inline'    script: |      docker images Some words of explanation:
  • Pool: this defines that pool where I will execute it. I know this will be executed on one DevOps build agent. This is important: as such, if you have multiple agents in a pool, you actually need to make sure this yaml is executed on all agents (because you might need the Docker images on all agents). Yet, this indicates that when you work with multiple build agents, this might not be the best approach.. .
  • Variables: I used a variable group here to share the sasToken as a secret variable over (possibly) multiple pipelines. The rest of the variables are quite straight forward: I’m not using the “automatic” naming convention from the BcContainerHelper, but I’m using my own. Not really a reason for doing that – it just makes a bit more sense for me ;-).
  • Steps: I’ll first install (of upgrade) the BcContainerHelper on my DevOps Agent and flush the artifact cache if too old (7 days retention). Next, I’m simply using the BcContainerHelper to create all images that I will need for my configured pipelines. You see that I have an example for:
    • A specific version
    • A latest current release version
    • A next minor (the next CU update)
    • A next major (the next major version of BC)
Schedule the pipeline to run regularly
Creating a pipeline based on a yaml is easy – but scheduling is quite tricky. Now, there might be a better way to do it – but this is how I have been doing it for years now:
1 – When you edit the pipeline, you can click the tree dots on the top right corner, and click “Triggers”
In the Triggers-tab, override and disable CI (you don’t want to run this pipeline every time a commit is being pushed)
Then, set up a schedule that suits you to run this pipeline, like:
And that’s it!
ALOps
If you’re an ALOps user, this would be a way to use the artifacts today. Simply build your images, and use it with the ALOps steps as you’re used to.
We ARE trying to up the game a bit, and also make it possible to do this inline in the build (in the most convenient way imaginable), because we see it necessary for people that are using a variety of build agents, which simply can’t be scheduled (as they are part of a pool). More about that soon!
waldo: Installing a DevOps Agent (with Docker) with the most chance of success Blog bot NAV: Blogs 0 14.07.2020 21:16
waldo: Installing a DevOps Agent (with Docker) with the most chance of success Blog bot NAV: Blogs 0 14.07.2020 15:11
waldo: Where to find the Microsoft Dynamics 365 Business Central (and NAV) Docker Images (updated) Blog bot NAV: Blogs 0 01.02.2019 08:12
waldo: Where to find the Microsoft Dynamics 365 Business Central (and NAV) Docker Images Blog bot NAV: Blogs 0 24.01.2019 07:17
Часовой пояс GMT +3, время: 02:51.
