04.11.2017, 01:13 | #1 |
axtoday: How to add a new operating unit type
Источник: http://axtoday.blogspot.com/2017/11/...unit-type.html
============== For AX2012, you can follow the steps in this link https://msdn.microsoft.com/en-us/library/gg989762.aspx Couple of important points:
For D365, it is quite similar to the steps in AX2012, however in the view it should have a method called registerDimensionEnabledTypeIdentifier and you should use the view name that you just created. This will then add the new operating unit as a dimension type. Источник: http://axtoday.blogspot.com/2017/11/...unit-type.html
